ASUS VivoWatch features exclusive VivoPulse technology, which uses the built-in optical sensor to continuously, accurately, and safely monitor your heart rate without the need to wear an uncomfortable chest strap. ASUS VivoWatch uses these precise heart rate measurements to show you the number of calories you burn each day and provide helpful insights into your exercise and sleep quality.
Ensure you are getting the rest you need to feel your best every day. ASUS VivoWatch measures and analyzes your heart rate, sleep time, and how much you toss and turn to give you an insightful look into your sleep quality. ASUS VivoWatch also helps you wake up easily each morning with a gentle, vibrating alarm.
The Happiness Index(HI)is a simple numeric score based on your sleep and exercise measurements that provides a quick summary of the overall healthiness of your lifestyle.
