E406 is extremely portable at just 17.6mm thin and weighs just 1.3kg. It's an everyday laptop that keeps you productive and entertained - anywhere.
Smart performance
The E406 features ultra-fast 802.11ac Wi-Fi for speeds up to 3x faster than 802.11n. From daily computing tasks to entertainment, this versatile laptop has everything you need.
NanoEdge display
With a thin 7.8mm bezel and 76.5% screen-to-body ratio, the NanoEdge display on E406 provides you with more screen area for more immersive viewing.
Fanless design with low operational noise
The fanless design of the E406 keeps noise levels down, ideal when you want to work silently in libraries or coffee shops. This approach also decreases power consumption, and improves system reliability by avoiding potential dirt-related component failures.
Enjoy worlds of color and pixel-perfect video
ASUS-exclusive technologies ensure only the very best visual experience. ASUS Splendid visual optimization technology provides the very best visuals for any type of content. It features four display modes: Normal mode is ideal for daily tasks, Vivid mode optimizes contrast to deliver stunning photos and video; Eye Care mode reduces blue-light levels to ease eye strain and Manual mode allows for personalized color adjustments. ASUS Tru2Life Video technology intelligently optimizes each pixel in the video frame to increase sharpness and contrast by 150% so you'll enjoy the best possible image quality.
Stay cool - even after hours of use
Laptop cooling is important because it directly affects your computing experience. ASUS IceCool technology uses thin heat pipes and clever internal layout design to create an efficient cooling system that keeps the average palm rest surface temperature below 36°C - lower than body temperature - so you get robust cooling performance and a comfortable user experience.
A safe fast-charging and longer-lasting battery
You can work out of coffee shops or libraries for the entire day without having to look out for a power socket.
