Quicklinx: | C15RWS00 |
Mfr#: | E200HA-FD0004TS |
Mobile performance, elegantly crafted - that's the Vivobook E200HA from Asus. Delivering superior performance when you're on the go, the Vivobook is designed to keep you productive all day long.
With numerous USB ports, a MicroSD card slot and a micro HDMI port, the Asus Vivobook has everything you need to stay connected when you need to be. Its generous battery life means you'll have plenty of time to get those everyday tasks done when you're out and about.
It's equipped with a powerful 1.84GHz Intel Atom processor, along with 2GB of RAM and a 32GB hard drive - so there's ample space for those essential documents. This practical notebook weighs less than 1kg, so its compact design means it's easy and convenient to carry around with you.
The Asus Vivobook E200 proves that performance and practicality don't have to come at the expense of affordability. For easy on-the-go computing, it could be the perfect solution.
