Get TUF core reliability and cooling tech on Intel®B85 mATX motherboard
- LGA1150 Socket for 4th Generation Intel® Core™ i7/i5/i3, Pentium®/Celeron® Processors
- TUF Thermal Radar Core - Complete System Cooling, Customized Fan Tuning
- TUF Components [10K Ti-Caps, Alloy Chokes & MOSFETs; Certified by Military-standard] - Certified for Tough Duty
- Server-grade Reliability Test - Promised Reliability with Strict Testing
- DIGI+ VRM - Herald the Arrival of a New Digital Power Design Era
- ESD Guards - Ultra-protection Against Electrostatic Discharge
TUF /t?f/, stands for The Ultimate Force. The TUF series delivers a "tough" image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability
Thermal Radar Core: Complete system cooling, customized fan tuning
ASUS TUF Thermal Radar Core enables complete system cooling management - quickly, easily and safely. Customizable controls allow you to adjust fan speeds, allowing the temperature to be tuned with just a single click. And talking of single-click simplicity, live update ensures that your Thermal Radar Core is never out of date - just click the button to check for updates.
