The ASUS USB-N53 is a dual-band USB adapter that provides flexible dual-band connection for lag-free streaming and high performance networking. It also has a superior antenna design for extensive wireless coverage.
With the bundled USB cable, you can flexibly adjust the antenna to receive the strongest signal. A friendly user interface utility allows you to install and use the application easily, making the USB-N53 a fantastic USB Wi-Fi Adapter both at home and on the road.
Flexible Dual-band connection for lag-free streaming and high performance networking.
Power signal transmission for extensive wireless coverage.
Contains a USB cable that allows you to adjust the adapter for enhanced reception.
