ASUS SD424-YB commercial displays feature a built-in multimedia player that automatically detects and plays a variety of commonly used media file formats. The SD424-YB supports up to full HD 1920 x 1080 content and features a 178-degree wide-view angle panel that provides stunning images even when viewed from extreme angles. SD424-YB features brightness of 350 cd/m2, making them ideal for indoor wall-mounted, shelved, or end-cap installations. The SD424-YB also has built-in speakers that provide clear audio to accompany the visuals. With everything housed in a single unit, the SD424-YBs' all-in-one design makes it ideal for small businesses. It is a cost-effective solution that is easy to set up too, giving users a high return on investment.
Simply insert an USB storage device to the embedded media player for cable-free playback. It eliminates the need for a connection to a PC or other multimedia device. The all-in-one design of the SD424-YB ensures quick and easy set up.
The SD424-YB can automatically detect and play files from an USB drive. It supports various video, audio, and image file formats to give users more options when it comes to creating display materials.
