The compact size-10.9L contains all possibilities. It is convenient to move and saving more space for you. With many hidden mechanical designs and its high sleek piano-black, the simple and elegant product fits all surroundings at home. It's not just a computer; it is an artistic decoration.
Glossy surfaces and an eye-catching power button, which are inspired from the halo of lunar eclipse in the night. The lighting shows powerful indications when switched on; in contrast, all the rest of the form sits quietly. It is just like a poem or painting describing the silent dark sky with a full moon and a mirror-like lake reflecting the bright shadow.
The highly integration of mechanism and MB design creates the best placement and air flow. Also, P6-P5G41E has unique Q-Fan Technology detected the CPU loading and temperature automatically. Therefore P6-P5G41E provides the best thermal & acoustic solution to build the quiet working environment.
P6-P5G41E supports DirectX10 which equips 3-D graphics-rendering capabilities in games and high-end 3-D applications. Plus the HDMI connector and the theater-like HD 8 channel audio, a new experience of home entertainment is evolved for you.
P6-P5G41E supports DDR3 memory that features data transfer rates of 1333/1066/800 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of system memory to boost system performance.
DriveClone Pro 7 is an advanced and available recovery tool which stores user data, applications and the operating system in the host-protected area of the hard drive just in few seconds and recover it in few minutes. Users can easily recover system to any state without restore CDs. No need to worry about losing data due to virus attacks.
To green our earth, P6-P5G41E equips the power saving design - EPU. It not only saves your money but also supports more stable electric force. Moreover, P6-P5G41E follows the stern EUP rule to show the resolution of protecting the world.
P6-P5G41E features ASUS-exclusive utility AI Manager, which includes AI Disk for clearing your browsers' history, cookies, files and even your recycle bin. AI Security enables you to secure all your devices, while AI Boot allows you to prioritize your boot order. My Favorites helps you add all your frequently used applications, and you can even seek technical help from ASUS via Support. Information allows you to have a one-stop view of your system information.
Express Gate offers an optional Linux OS boot-up that allows you to enjoy instant access to commonly used functions like accessing the Internet, VoIP, and Web emailing without entering Windows.
