The ROG team aimed to provide a compact keyboard without compromise, masterfully incorporating arrow and navigation keys into a 65% keyboard layout. And at just 306 mm in length, ROG Falchion NX is almost the same size as a 60% keyboard. It gives you all the functions of a normal keyboard without taking up much desktop space.
Interactive touch panel
An innovative touch panel on the left flank of ROG Falchion NX lets you conveniently adjust volume, or create shortcuts for switching apps, or copying and pasting. It can also be programmed for use as a macro key for more intuitive controls for gaming.
Dual-mode connectivity and up to 450-hour battery life
A near-zero latency 2.4 GHz RF connection and up to 450 hours of battery life deliver the stability and longevity gamers need for the ultimate gaming experiences. It can also be used in wired USB mode.
Durable PBT Doubleshot Keycaps
ROG PBT Doubleshot Keycaps provide a unique and premium feel, as well as offer long-lasting durability. Key design has been optimized with mid-height keycaps and a shorter stem to reduce key wobble and provide a more comfortable user experience. The precise double-shot molding process results in translucent keycaps that feature seamless ROG script for a unique look, giving ROG Falchion NX consistent lighting and a look that's unmistakably ROG.
Polycarbonate keyboard cover
The transparent polycarbonate keyboard cover provides superb protection when you're storing or taking ROG Falchion NX to LAN parties. The cover can also be placed under the keyboard when in use, to give the underside RGB lighting a diffused look.
Wireless Aura Sync per-key RGB lighting
ROG Falchion NX is the first keyboard to feature wireless Aura Sync RGB lighting. With Aura Sync RGB, the entire color spectrum and a range of dynamic lighting effects are at your command, so you can create a keyboard that's uniquely yours. Customize and shine in your own way, wirelessly.
Fast-charge
A 30-minute charge time lets you play for up to 32 hours with RGB lighting off.
Onboard memory
Save up to six profiles, including up to five custom schemes, and use them anytime, anywhere.
100% anti-ghosting & N-key rollover
Every keystroke is registered accurately, no matter how many keys are pressed.
Touch panel and windows lock keys
Disable the touch panel and Windows key with a single press for undisturbed gaming.
Function lock key
Toggle between Number or Function (Fn) key input to easily switch modes for different scenarios.
On-the-fly macro recordings
Record macros on the fly and map them to fully programmable keys.
ASUS ROG Falchion NX - keyboard - UK - grey, black Input Device
