Crosshair IV Extreme motherboards deliver the perfect platform for AMD 890FX, brandishing jaw-dropping muscle. The parade of power features is comprehensive. Four GPU support goes with a thermal design that laughs in the face of outlandish temps as the Extreme Engine Digi+ harmonizes performance and power to prolong lifespans and cut on energy consumption.
Overclocking has never been so effortless - ROG Connect is the exclusive ASUS tweaking suite, controlling a host of parameters even remotely from another PC. RC Bluetooth pulls another milestone - Bluetooth overclocking from a smartphone. Now that's inspiring.
Meanwhile, the Crosshair IV Formula races to glory with a fusillade of innovations making it an ideal choice for PC gamers. The GameFirst engine was built with online in mind, optimizing connection speeds and destroying lag in its tracks for multiplayer domination even as heavy multitasking occurs in the background.
Expand AMD Hardcore Overclocking
- AMD Phenom II X6 support / AMD 890FX + SB850 chipset
- Dual DDR3 2133 (O.C.) support
- CrossLinx 3 Technology - Experience true graphics freedom
- ROG Connect- Plug and Overclock - Tweak it the hardcore way!
- RC Bluetooth - Smashes through all the barriers of conventional overclocking!
- USB BIOS Flashback - Refresh the BIOS can never be that easy
