ASUS STRIX R7 370 delivers pumped gaming performance and extreme reliability
1050 MHz engine clock for better performance and outstanding gaming experience.
DirectCU II with 0dB fan technology lets you enjoy light games in complete silence, and hardcore gaming 30% cooler with 3X-quieter performance.
Super Alloy Power boosts performance by reducing power loss, enhancing durability, and achieving cooler operation.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and lets you stream your gameplay instantly.
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours.
ASUS STRIX R7 370 gaming graphics cards packed with exclusive ASUS technologies, including DirectCU II with Dual Wing-Blade 0dB Fan Design for max air flow with 30% cooler and 3X quieter performance. This card features exclusive Super Alloy Power for 30% less power noise and 2.5X greater durability. It also has GPU Tweak II with XSplit Gamecaster, provides intuitive performance tweaking and lets you stream your gameplay instantly.
DirectCU II Cooling Technology
30% Cooler and 3X Quieter Performance
Exclusive DirectCU II cooling technology outperforms reference designs that transports 40% more heat away from the GPU -- a first for the industry! The design also includes 2.3X-larger heat-dissipation: this means performance that's 30% cooler three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise.
Max Air Flow with 105% More Air Pressure
0dB fans engineered with a patented, new wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards. The 0dB fans also let you enjoy games like League of Legends® and StarCraft® in complete silence -- because the fan stops completely when the GPU temperature remains below a set leve*. This makes DirectCU II the coolest and quietest graphics card in the market.
Super Alloy Power
A 6-phase power design that uses digital voltage regulators to minimize power noise by 30%, enhance power efficiency by 15%, widen voltage modulation tolerance, and improve overall stability and longevity by 2.5 times over reference.
Tweak Till Your Heart's Content
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the new Gaming Booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
Gaming Booster
One-click Performance Up
Visual effects: Boost your performance by turning off windows visual effects.
System Services: Automatically or manually turn off windows services or process.
Memory Defragmentation: Re-arrange & free your system memory without closing any processes.
