Quicklinx: | 9DL7WS00 |
Mfr#: | PA279Q |
The ASUS PA279Q is pre-calibrated at the factory for the highest accuracy and outstanding color space reproduction - 99% Adobe RGB, 100% sRGB, and 120% NTSC. With a wide color gamut of 99% Adobe RGB, the colors seen in photos will be reproduced faithfully and consistently in a way that cannot otherwise be on monitors with just an sRGB color space.
The PA279Q offers 10-bit display color for over one billion onscreen colors and support 14 bit internal lookup table (LUT), which gives smoother gradations and a more natural transition between hues.
The out-of-box settings are impressive as each PA279Q is pre-calibrated at factory to prove the best color accuracy. To ensure that each PA279Q produces the most accurate and consistent color, we carefully measure its ?E and gamma value and track its gray-scaling.
It even supports Gamma 2.2 for PC and Gamma 1.8 for Mac - offering users more flexibilities to work with. Each PA279Q guarantees industry-leading color accuracy, having been pre-calibrated to minimize the color difference to ?E (Delta E) of less than 2 - ensuring precise reading of color input and guarantees excellent color fidelity.
