The Professional Monitor with a Touch of Play
- IPS panel with 100% sRGB coverage and 178 wide viewing angle
- Every unit is factory-calibrated for superior color fidelity
- QuickFit Virtual Scale instantly boosts design efficiency by providing real-size document, photo and grid on screen
Ultimate Color Precision
High Color Accuracy with Low Delta E
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity.
178° Wide Viewing Angle
PA238Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
Flawless Gradation with 10-bit Look-up Table
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution
User-friendly Solutions
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Supporting Formats:
- Document: A4, letter
- Photo: 8"x10", 5"x7", 4"x6", 3"x5", 2"x2"
- Grid: Alignment, Centimeters, Inches
Versatile Comfort with Ergonomic Design
The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position
Customized Color Adjustment
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors
Picture-in-Picture and Picture-by-Picture
Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want
Hassle-Free Connection
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc
Mercury-free LED-backlit panel
Embedded LED backlight panel helps power saving and environmental protection with no mercury usage
