ASUS P8Z77-V Premium: The First Intel Certified and Windows Optimized Motherboard to Feature Thunderbolt Technology
World's 1st Windows®-based Thunderbolt Motherboard
Equipping with the fastest I/O, Thunderbolt onboard, it ramps up the transfer speed up to 10Gbps which is 2X faster than USB 3.0. Also supporting high resolution of a DisplayPort up to 2560 x 1600. No more messy cabling, it only requires one unified cable to transmit your high-performance storage and video capturing devices. Also, with the daisy-chain technology, it can connect up to 6 Thunderbolt devices which extends the extreme capability out of one compact port.
4-Way SLI/CFX Support
We prepare the greatest for the most enthusiastic users and the hunger for graphics is definitely on the top list. It features a unique PCIe 3.0 bridge chip to support 4-Way SLI/CrossFireX at x16/x16 or x8/x8/x8/x8 for unrivaled multi-GPU gaming performance. Explicit the best graphical performance onboard.
mSATA 32GB SSD Onboard
To minimize the efforts users might encounter, P8Z77-V PREMIUM get everything ready onboard. Armed with 32GB SSD , you don't have to prepare the extras to enjoy the Intel® Smart Response and Rapid Start Technology for a faster system performance and instant-on function.
Above all, the P8Z77-V PREMIUM also have full-collection of ASUS Z77 features which includes Dual Intelligent Processors 3 with Smart DIGI+ Power Control for ultra-precise tuning to CPU, iGPU and DRAM. Dual band Wi-Fi GO! support for complete cloud entertainment. Fan Xpert 2 for individual, customized fan control and more. Get prepared! The PREMIUM fever is now onboard!
- Dual Intelligent Processors 3 with Smart DIGI+ Power Control
- Thunderbolt Technology Onboard
- Dual band Wi-Fi 802.11n and Bluetooth 4.0/3.0+HS Support
- Wi-Fi GO!
- Fan Xpert 2
- ASUS SSD Caching II
- mSATA 32GB SSD Onboard
Specification
- LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
- Supports 22/32nm CPU
- Supports Intel® Turbo Boost Technology 2.0* * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
- Chipset Intel® Z77 Express Chipset
- 4 x DIMM, max. 32GB, DDR3 2800(O.C.)*/2600(O.C.)*/2400(O.C.)*/2200(O.C.)*/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz, non-ECC, un-buffered memory
- Dual channel memory architecture
- Supports Intel® Extreme Memory Profile (XMP) * Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
- 4 x PCI Express 3.0*/2.0 x16 slots (support x16; x16/x16; x16/x8/x8; x8x8x8x8 mode)
- 2 x PCI Express 2.0 x1 slots * PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
- Thunderbolt: VGA output support with max. resolution 2560 x 1600@60Hz / Data transfer rate up to 10Gbps / Daisy-chain up to 6 Thunderbolt devices
- Integrated Graphics Processor- Intel® HD Graphics support
- Multi-VGA output support: Thunderbolt/DisplayPort/HDMI port
- Supports Thunderbolt with max. resolution 2560 x 1600@60Hz
- Supports DisplayPort 1.1a with max. resolution 2560 x 1600@60Hz
- Supports HDMI with max. resolution 1920 x 1200@60Hz
- Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
- Maximum shared memory of 1696MB
- Supports NVIDIA® 4-Way SLI™ Technology
- Supports AMD® 4-Way CrossFireX™ Technology
- Supports LucidLogix Virtu MVP Technology* * LucidLogix Virtu MVP supports Windows 7 operating systems.
- Intel® Z77 Express Chipset with RAID 0, 1, 5, 10 support
- 2 x SATA 6.0 Gb/s ports (gray)
- 3 x SATA 3.0 Gb/s ports (blue)
- 1 x mSATA 3.0 Gb/s port with onboard 32GB SSD
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology*
- Marvell® 9230 PCIe SATA 6Gb/s controller - 4 x SATA 6Gb/s ports (navy blue) with RAID 0, 1, 10 support
- ASMedia® SATA 6Gb/s controller** / 2 x eSATA 6Gb/s ports with port multiplier support / * Supports on Intel® Core™ processor family with Windows 7 operating systems. ** These SATA ports are for data hard drivers only. ATAPI devices are not supported.
- Dual Intel® Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance and dual interconnect between the integrated LAN controller and physical layer (PHY)
- Intel® 82579V Gigabit LAN
- Intel® 82583 Gigabit LAN
- Wi-Fi 802.11 a/b/g/n supports dual frequency band 2.4/5 GHz
- ASUS Wi-Fi GO! Utility
- Bluetooth v4.0
- Bluetooth v3.0 + HS
- Realtek® ALC898 8-channel high definition audio CODEC
- Absolute Pitch 192khz/24bit true BD lossless sound
- BD audio layer content protection
- DTS UltraPC II
- DTS Connect
- Supports jack-detection, multi-streaming, front panel jack-retasking
- Optical S/PDIF out port at back I/O
- 1 x ASMedia USB 3.0 controller- supports ASUS USB 3.0 Boost UASP Mode.
- 2 x USB 3.0/2.0 ports at back panel(blue)
- Intel® Z77 Express Chipset- supports ASUS USB 3.0 Boost Turbo Mode.*
- 2 x USB 3.0/2.0 ports at mid-board for front panel support
- 6 x USB 2.0/1.1 ports (4 ports at mid-board, 2 ports at back panel) * The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
- BIOS 64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
- ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
- Form Factor ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
Back Panel I/O Ports
- 1 x Thunderbolt port
- 1 x DisplayPort
- 1 x HDMI port
- 1 x BT4 connector for ASUS Wi-Fi GO! card (Wi-Fi 802.11 a/b/g/n and Bluetooth v4.0/3.0+HS)
- 1 x Optical S/PDIF out
- 2 x eSATA ports
- 2 x Intel® LAN (RJ45) ports
- 4 x USB 3.0/2.0 ports (blue, 1 supports USB BIOS Flashback)
- 2 x USB 2.0/1.1 ports
- 1 x USB BIOS Flashback button
- 8-channel Audio I/O ports
Internal I/O Connectors
- 1 x USB 3.0/2.0 connector supports additional 2 USB ports (19-pin)
- 2 x USB 2.0/1/1 connectors support additional 4 USB ports
- 6 x SATA 6.0Gb/s connectors ( 2 x gray; 4 x navy blue)
- 3 x SATA 3.0Gb/s connectors (blue)
- 1 x mSATA connector with 32GB SSD onboard
- 1 x CPU Fan connector (4-pin)
- 1 x CPU Optional Fan connector (4-pin)
- 4 x Chassis Fan connectors (4-pin)
- Front panel audio connector (AAFP)
- 1 x S/PDIF out header
- 1 x TPM connector
- 24-pin EATX Power connector
- 8-pin EATX 12V Power connector
- System Panel(Q-Connector)
- 1 x MemOK! button
- 1 x Clear CMOS button
- 1 x TPU switch
- 1 x EPU switch
- 1 x Power-on switch
- 1 x Reset switch
Accessories
- 2 x Wi-Fi ring moving antennas
- 1 x ASUS Wi-Fi GO! card (Wi-Fi 802.11 a/b/g/n and Bluetooth v4.0/3.0+HS)
- 1 x ASUS USB 3.0 front panel box
- 1 x 4-Way SLI card
- 1 x 3-Way SLI card
- 4 x Serial ATA 6.0Gb/s cables
- 2 x Serial ATA 3.0Gb/s cables
- 1 x ASUS SLI bridge connector
- ASUS Q-Shield
- 2 in 1 Q-connector
- User's manual
Thunderbolt™ Onboard
TAn industry first, ASUS has placed Thunderbolt I/O technology onboard, and are set to revolutionize the speed at which peripherals and displays operate. Featuring a maximum bi-directional speed of 10 Gbps, Thunderbolt is 2 times faster than USB 3.0 and an incredible 20 times faster than USB 2.0. And with the ability to daisy-chain up to six devices without the need for a hub or switch, that means less overheard for a clutter free computing experience. For example, users can connect multiple native Thunderbolt storage devices, an HD video capture device and even an HD display to a single Thunderbolt chain while maintaining maximum throughput. You can also connect a DisplayPort, DVI, HDMI or VGA display with an existing adapter.
ASUS SSD Caching II: Multiple SSD Caching, Instant Upgraded Speed
SSD Caching II has been upgraded with a multiple caching function, adding four extra SATA 6Gb/s onboard. This feature offers performance upgrades by using multiple installed SSDs with no capacity limitations as a cache for frequently accessed data. It also allows user to choose the combinateion that suits their needs. For example, you can choose three SSDs matched with one HDD or two SSDs with two HDDs. Harness a combination of SSD-like performance and response and hard drive capacity with a single click, without the need to reboot for instant activation and complete ease of use. As an added bonus, it can even prevent data loss with the included backup function, so you can rest easy knowing your data is secure.
