The VivoPC K20CD is a stylish and elegant PC for your home. From its brushed metal finished front panel to its elegant power bar, the well-crafted VivoPC K20CD makes a wonderful addition to any room of your house. The chassis takes up very little space, allowing you to place it under the table in your study or beside your TV.
Smart multimedia performance
The VivoPC K20CD is powered an incredible processor to give you significantly faster and more efficient multitasking performance. The VivoPC K20CD enhances your daily computing experience, making online shopping, writing blogs, conducting presentations, or watching movies very enjoyable.
Expansive audio
A professional codec ensures precise sound performance; while an optimized amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass. Additional signal processing helps fine tune the hardware, filtering noise and improving clarity so you can enjoy amazing audio.
Environmentally friendly and ultra-quiet
The VivoPC K20CD isn't just superb in performance, it's extremely quiet as well. You won't be disturbed when you leave it on overnight, as it runs whisper-quiet. No more disturbance when you're studying or busy on work.
USB 3.1 transmission
The VivoPC K20CD features USB 3.1 transfering data for incredible speed. Besides, it also features all the connectivity options you need. HDMI output port lets you hook your VivoPC K20CD up to an HDTV to supersize your entertainment.
ASUS VivoPC K20CD UK039T - mini PC - Core i5 6400 2.7 GHz - 8 GB - HDD 2 TB
Personal computer - mini PC
Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
1 (total) / 0 (free) x CPU , 2 SO-DIMM 260-pin , 1 (total) / 1 (free) x PCIe x16 , 1 Mini PCIe
3 x USB 3.0 (2 in front) , 2 x USB 3.1 , 1 x HDMI , 1 x VGA output , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
