ASUS STRIX GTX 780 delivers 15% faster performance
- 941 MHz Boost clock for better performance and outstanding gaming experience.
- DirectCU with 0dB fan technology lets you enjoy light games in complete silence, and hardcore gaming 20% cooler with 3X-quieter performance!
- DIGI+ VRM with 10-phase Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
- GPU Tweak Streaming Share on-screen action in real time - so others can watch live as games are played.
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours.
Strix GTX 780 is the new gaming graphics card from ASUS for those who survive on the very edge of instinct. Equipped with the powerful GeForce® GTX 780 GPU, Strix GTX 780 delivers 38%-cooler operation and the ability to play in complete silence! Exclusive DirectCU II technology keeps things super-cool while our new 0dB silent-fan technology means you can enjoy total peace -- even when playing games at HD resolutions of up to 1920 x 1080 pixels and with a GPU temperature of up to 65°C! Strix GTX 780 also benefits from DIGI+, an exclusive voltage-regulation module (VRM) for incredible stability and reduced noise. You also get GPU Tweak, a brilliant utility that teases maximum performance from the GPU and lets you live stream your enhanced gameplay!
DirectCU II with 0dB Fan Technology: 38% cooler. Silent gaming.
Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports 40% more heat away from the GPU -- a first for the industry! The design also includes 220%-larger heat-dissipation: this means performance that's 38% cooler and three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with 0dB fan technology that lets you enjoy games like League of Legends® and StarCraft® in complete silence -- because the card's thermal design is able to keep GPU temperature below 65°C, so the fan stops completely!
Graphics Engine
- NVIDIA GeForce GTX 780
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 6GB
- Engine Clock: GPU Boost Clock : 941 MHz
- GPU Base Clock : 889 MHz
- CUDA Core: 2304
- Memory Clock: 6008 MHz ( 1502 MHz GDDR5 )
- Memory Interface: 384-bit
- Interface: DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D), HDMI Output : Yes x 1 , Display Port : Yes x 1 (Regular DP)
- HDCP Support : Yes
- Accessories: 1 x Power cable, 1 x DVI to D-Sub adaptor, 1 x SLI Bridge
- Software: ASUS GPU Tweak & Driver
- Dimensions: 11.3 " x 5.8 " x 1.7 " Inch / 28.7 x 14.7 x4.31 Centimeter
