ASUS GeForce® GTX 650: no power plugs, just graphics power!
- Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference
- Resist dust and particles for 25% longer graphics card longevity
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
- Power-plug free cards get you instant graphics upgrades with just motherboard power
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
Play games with advanced effects such as blazing explosions and lifelike characters with 10X faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time.
ASUS Exclusive Innovation
- Super Alloy Power: Enhanced durability and cooling - Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
- Dust-Proof Fan: 25% longer graphics card lifespan - Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25%* through increased dust and particle resistance.
- GPU Tweak: Detailed specs and actual card status with GPU-Z, Monitoring widget provides real-time and detailed multi-parameter info, 2D/ 3D switcher can lock the card in 3D mode for higher benchmarks, Automatically check and update drivers and BIOS versions, Sync GPU clocks and voltages for easier overclocking
- Unplugged: Easy graphics card upgrades using only motherboard power - Attain better graphics without the messy cables or buying a bigger power supply. GTX650-E-1GD5 gets all its power directly from the PCI Express slot, leading to a neat yet capable graphics configuration.
- 2GB GDDR5 Memory: On-board memory for the best gaming experience & the best resolution.
Graphics GPU Features
- Powered by GeForce® GTX 650
- GeForce® CUDA Support: Unlocks the power of GPU's processor cores to accelerate the most demanding system tasks
- NVIDIA® PhysX® ready: Play games with advanced effects such as blazing explosions and lifelike characters with 10X faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time.
- NVIDIA® 3D Vision™ Surround Ready: Transform hundreds of PC games into stereoscopic 3D and enjoy immersive full HD 3D gaming across three displays at an incredible 5760x1080 resolution.
- PCI Express 3.0: Delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication.
- Microsoft DirectX 11.1 API (feature level 11_0): Brings new levels of visual realism to gaming on the PC and get top-notch performance
- Graphics Engine: NVIDIA GeForce GTX 650
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 2GB
- Engine Clock: 1071 MHz
- CUDA Core: 384
- Memory Clock: 5000 MHz ( 1250 MHz GDDR5 )
- Memory Interface: 128-bit
- Resolution: D-Sub Max Resolution : 2048x1536, DVI Max Resolution : 2560x1600
- InterfaceL D-Sub Output : Yes x 1, DVI Output : Yes x 1 (DVI-D), HDMI Output : Yes x 1 , HDCP Support : Yes
- Power Consumption: up to 75Wno additional PCIe power required
- Software: ASUS Utilities & Driver, GPU Tweak
- ASUS Features: Fan Sink
- Dimensions: 7.79 " x 4.54 " x 1.54 " Inch, 19.78 x 11.53 x3.91 Centimeter
