PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
ASUS GT610-SL-2GD3-L Gigantic 2GB on a low profile design!
The newly arrived ASUS GT610-SL-2GD3-L ships with 0dB silent thermal and low profile design with low profile bracket bundled that could fit end user's mini home theater pc and offer the best home theater enjoyment. Especially, its 2GB massive memory size can provide the best gaming experience in great resolution. Furthermore, ASUS GT610-SL-2GD3-L built with Super Alloy Power technology for enhanced durability. Besides, ASUS GT610-SL-2GD3-L also comes with exclusive GPU Tweak utility, which allows users to modify clock speeds, voltages, and fan performance.
- 2GB massive memory size for smooth gaming experience
- Exclusive 0dB thermal design dissipates heat efficiently without any noise
- Super Alloy Power blends selected elements under ASUS exclusive formula, resulting in a 15 % performance increase, 2.5 times longer product lifespan and 350C cooler operation
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
- Low profile design with low profile bracket bundled
Spec
- Model GT610-SL-2GD3-L
- Graphics Engine GeForce GT610
- Bus Standard PCI Express®2.0
- OpenGL OpenGL® 4.2
- Video Memory 2GBDDR3
- Engine Clock 810MHz
- Memory Clock 1200MHz (600MHz DDR3)
- Memory Interface 64bit
- RAMDAC 400MHz
- DVI Max. Resolution 2560 * 1600
- D-SubMax. Resolution 2048 * 1536
- D-Sub Output YES, native
- DVI Output YES, native
- HDMI Output YES, native
- HDCP compliant YES
- Adaptor/Cable Bundled 2X 1-slot LP Bracket
- Software Bundled ASUS Utilities & Driver
- Dimension 7.3"x 4.7"x 1.6"
