            ASUS Dual Radeon™ RX 6600 V2 8GB GDDR6 is armed to dish out frames and keep vitals in check
- OC mode: Up to 2491 MHz (Boost Clock)/up to 2064 MHz (Game Clock)
- Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure.
- Dual ball fan bearings can last up to twice as long as sleeve bearing designs.
- Auto-Extreme Technology uses automation to enhance reliability.
- A protective backplate prevents PCB flex and trace damage.
