| Quicklinx: | 9PP3WS00 |
| Mfr#: | DSL-AC68U |
Future-proofed versatility with the world's fastest wireless speeds
The ASUS DSL-AC68U is the world's fastest ADSL/VDSL modem Wi-Fi router, with combined dual-band data rates of up to 1900 Mbps. On the 5GHz band, 802.11ac gives 1300 Mbps wireless data rates, while Broadcom® TurboQAM™ technology super-charges 2.4 GHz 802.11n performance from 450 Mbps to 600 Mbps with compatible devices. Compatible with ADSL2/2+, ADSL, VDSL2, fiber and cable services, the top specification completes future-proofing.
Three external antennas boost coverage to the next level, so you can enjoy lag-free gaming and streaming almost anywhere around the house. ASUS AiRadar with universal beamforming technology enhances the Wi-Fi stability and improves coverage up to 150%*. Most importantly, the universal beamforming not only works on 802.11ac clients, but also 802.11a/b/g/n clients.
Powered by dual dedicated CPUs for wired and wireless connections, the DSL-AC68U eliminates the performance drops that plague other routers with busy networks and maximizes both range and stability. So even on the busiest home networks, HD video streaming is always smooth, the latency low for online gaming and VoIP calls, and file downloads are never interrupted.
The easy-to-use ASUSWRT graphical user interface unlocks the power of the DSL-AC68U giving robust control to optimize your network for you. 30-second set-up and easy traffic management means even network newbies can enjoy its sophisticated features, while power users will love its IPv6 support, multiple wireless SSIDs and secure VPN access.
One device, two functions
With a choice of DSL or Ethernet WAN connections, DSL-AC68U can be used a DSL modem plus wireless router, or as a standalone wireless router. You can choose the mode to suit your needs, saving energy and clutter by replacing two separate power-hungry devices. Whether for a basic home setup or an advanced wireless network, DSL-AC68U has all the flexibility you need. You can also let two modes work simultaneously and manage them with ASUSWRT dual WAN function.
Works with any kind of internet connection
Works with any kind of internet connection DSL-AC68U supports all common types of DSL connection, including ADSL2, ADSL2+, ADSL and VDSL2. Thanks to its Ethernet WAN option, it can also be used seamlessly with any fiber or cable-based modem with an Ethernet connection. This makes it ideal for those who intend to upgrade their ISP in the future.
Two CPUs for fast and stable connections
The DSL-AC68U offers dual CPU performance and flexibility. Its twin processors each optimize wired and wireless connections. By separating wired VDSL/ADSL and Wi-Fi networking into two compute modules with their own dedicated processing power, the DSL-AC68U achieves maximum performance for both connection types with no compromises.
World's fastest AC Wi-Fi with TurboQAM™ Wi-Fi acceleration
Powered by 5th generation Wi-Fi (5G Wi-Fi), the new 802.11ac Broadcom chipset gives the DSL-AC68U superfast Gigabit wireless speeds. Compared with current 802.11n, the DSL-AC68U delivers up to 1.3Gbps at 5 GHz, which is 3X faster than 802.11n! The upgraded bandwidth has the higher capacity you need to increase Wi-Fi enjoyment at home. With notebooks, desktops, pads, and smartphones now all Wi-Fi-reliant, it's time to upgrade to the next generation so you can expand you connectivity now and in future.
AiRadar delivers 150% Wi-Fi coverage*
ASUS AiRadar intelligently strengthens wireless device connectivity using precise directional signal amplification for extended coverage, increased data throughput speed and enhanced stability. Because connection strength varies based on your environment, DSL-AC68U uses three external high-gain antennas and universal beamforming to detect wireless device locations and shape transmissions so they're optimized for the fastest, most stable connection strength. Most importantly, the universal beamforming not only works on 802.11ac clients, but also 802.11a/b/g/n clients.
Highest USB speeds
The ASUS DSL-AC68U wireless modem router arrives loaded with USB 3.0 port. USB 3.0 offers up to ten times faster transfers than USB 2.0. FTP, HTTP, and UPnP server functions all achieved with instant ease and speed, alongside 3G/4G connection sharing and ASUS AiDisk remote file access and content streaming from a wide range of compatible devices. Best of all, downloading can occur 24/7 even with the PC off, and printers can be shared too.
Gigabit Internet browsing with hardware NAT
Equipped with powerful hardware NAT acceleration and built-in Gigabit Ethernet, the DSL-AC68U wireless modem router gives you full Gigabit LAN-to-WAN performance of more than 900 Mbps, which is over 4.5 times that of traditional software-based NAT Gigabit routers. This reduces the possibility of bottlenecks on fast internet connections.
Sync. Share. Stream. Your world on demand
ASUS AiCloud keeps you connected to your data wherever and whenever you have an internet connection. It links your home network and online Web storage service* and lets you access it through the AiCloud mobile app on your iOS or Android smartphone or through a personalized URL in a Web browser. Even better, the new Router-to-Router Sync function allows you to synchronize your stuff with storage devices connected to other compatible ASUS routers-- it's as simple as choosing a sync folder. Sharing with friends and family is now easier than ever!
* Works with select Web storage services only.
Robust control and optimization with ASUSWRT
With the ASUSWRT dashboard UI, setup, monitor, and control network applications all in one intuitive area. On top of 30-second setup, multi-device detection, and flexible settings that make the most of your network performance, it's been upgraded with quick scanning of USB storage connected to routers to verify data integrity and drive health. Dual WAN enables having two connections/ISPs on one router, with load balance and failover mode for added stability and redundancy to ensure uninterrupted internet access.
Do you game a lot, or spend most of your time streaming videos? Whatever your planned use is, the DSL-AC68U has Quality of Service (QoS) standards that let you select how much bandwidth is prioritized for virtually any task. Plus, the traffic monitor allows you to check your Web usage in a clear graphical interface. Try our ASUSWRT
3-step easy setup through your pad, smartphone, or PC
Use your smartphone, tablet, or PC to effortlessly set up your ASUS router in less than 30 seconds* and in only 3 easy steps. Simply connect the cables to the router, open a Web browser, and follow the setup wizard to get you to the internet in no time.
* ASUS-tested and verified setup time. Actual duration may vary by ISP, specific connection type, location, and other factors.
Step1: Open web browser.
Step2: Enter ID/Password.
Step3: Done!
VPN server and VPN client support for total security and privacy
DSL-AC68U offers a sim
