Asus HD7970-DC2T-3GD5 The Coolest and Quietest Radeon HD7970 "HD7970-DC2T-3GD5" 28NM with fantastic ASUS design Features
The newly arrived ASUS HD7970-DC2T-3GD5 ships with 1000MHz overclocked GPU and 3GB GDDR5. To fully harness the power of 28nm GPUs, HD7970-DC2T-3GD5 comes with ASUS exclusive DirectCU II fansink and six flatten copper heat-pipes directly contacted the GPU. The 20% larger dissipation area, not only makes this card 20% cooler but also leads 14dB quieter operation than reference card. ASUS HD7970-DC2T-3GD5 is also built with DIGI+ VRM and 12-phase Super Alloy Power technology for precise digital delivery and enhanced durability.
In addition, proprietary VGA Hotwire allows users to alter voltages directly on a hardware level, resulting in more precise modification. GPU Tweak utility helps users modify and tune clock speeds, voltages, and fan performance via an intuitive interface. For the ultimate immersive gaming experience, HD7970-DC2T-3GD5 supports dual DVI and four DisplayPort connectors to drive up to six screens with AMD Eyefinity™ 6 - achieving HD/ 4K resolution with no additional adapters. HD7970-DC2T-3GD5, the coolest and quietest HD 7970 graphics card, provides perfect gaming experience!
ASUS Exclusive Innovations
? 1000MHz factory overclocked
? 20% cooler and 14dB quieter performance with ASUS exclusive Direct-CU II thermal solution
? ASUS DIGI+ VRM technology with 12-phase Super Alloy Power for precise digital delivery and enhanced durability
? VGA Hotwire hardware overvolting and GPU Tweak software tuning.
? One card drives up to six screens with AMD Eyefinity™ 6: four DisplayPorts and dual DVIs provided!
Key Selling Points
- 28nm GPU: Less power consumption & more efficient transistor
- PCIE 3.0: Delivers double the bandwidthper lane of PCIe Gen 2 for faster GPU -CPU communication
- Microsoft® DirectX® 11 Support: Bring newlevels of visualrealism to gaming on the PC and gettop-notch performance.
- AMD Eyefinity Technology: Extend the View across 6Displaysto immerse yourself in gameplay and entertainment
- CrossFire: Multi-GPU technology for extreme performance
- AMDD3D™ Technology: Optimize stereoscopic 3D gaming and movie-watching entertainment
- Microsoft® Windows® 7Support: Enable PC users to enjoy an advanced computing experience and to do mor
Key specification
- Graphics Engine AMD Radeon™ HD 7970
- Bus Standard PCI Express® 3.0
- OpenGL OpenGL® 4.2
- Video Memory 3072MB GDDR5
- Engine Clock 1010 MHz overclocked Edition
- Stream Processors 2048
- Memory Clock 5600MHz (1400MHz GDDR5)
- Memory Interface 384 bit
- RAMDAC 400MHz
- DVI Max. Resolution 2560 * 1600
- D-Sub Max. Resolution 2048 * 1536
- DVI Output
- 1x Native single-link DVI-I
- 1x Native Dual-link DVI-D
- HDMI Output 1x Via DVI to HDMI Adapter
- HDCP compliant YES
- DisplayPort 4x Native DisplayPort
- Adapter/Cable Bundled: 1x CrossFire Bridge / 1X Power Cable / 1x DVI to HDMI Adapter
- Software Bundled: ASUS Utilities & Driver / GPU Tweak
- Dimension The card size is 11 x 5.1 x 2.1 inches
