R7250-1GD5: Great value graphics with superior stability
- Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
- Dust-proof Fan design increases particle resistance and extends card lifespan by up to 25% longer than reference.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
Raging Cool For the Win! ASUS Exclusive Innovation
Super Alloy Power: Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
Dust-Proof Fan: 25% longer graphics card lifespan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25%* through increased dust and particle resistance.
GPU Tweak: Real-time intuitive graphics tuning
- Shows detailed specs and actual card status with GPU-Z
- Sync GPU clocks and voltages for easier overclocking
- Monitoring widget provides real-time detailed multi-parameter info
- 2D/3D switcher locks cards in 3D mode for higher benchmarks
- Automatically checks and updates drivers and BIOS versions
- Stream on-screen action to the web in full HD, with just a click
- Set your own headline for the streaming window
1GB GDDR5 Memory
On-board memory for the best gaming experience & the best resolution
Graphics GPU Features
- Powered by AMD Radeon™ R7 250
- AMD App Acceleration: Speeds up daily applications such as web browsing and video playback. Also the first to provide support for both OpenCL, C++ AMP, and DirectCompute 11.
- AMD PowerTune technology: Intelligent power monitoring in the AMD Radeon™ graphics to enable higher clock better performance in your favorite games.
- AMD ZeroCore Power technology: Allows your AMD Radeon graphic to consume virtually no power when in idle state. It even shuts down additional GPUs in AMD CrossFire. technology mode to consume less when they're not in use.
- Microsoft DirectX 11.2 API: Brings new levels of visual realism to gaming on the PC and get top-notch performance. MicrosoftR Windows 8.1 compatible
- MicrosoftR Windows 8.1 compatible: Gives you access to advanced computing experiences with the latest operating system so you get more done with your PC
I/O Ports Highlight
- 1 X Single-link DVI-D
- 1 X Native HDMI
- 1 X Native VGA
- Graphics Engine: AMD Radeon R7 250
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 1024MB
- Engine Clock: 1000 MHz
- Memory Clock: 1150 MHz ( 4600 MHz GDDR5 )
- Memory Interface: 128-bit
- Resolution: DVI Max Resolution : 1920x1200
- Interface: DVI Output : Yes x 1 (DVI-D)
- HDMI Output : Yes x 1
- HDCP Support : Yes
- Software: ASUS GPU Tweak & Driver
- Dimensions: 16 x 11.1 x3.4 Centimeter
