ASUS R7 240 delivers superb graphics performance without a single decibel of noise - just perfect for your home-theater PC (HTPC). Exclusive super alloy power components, including incredibly robust concrete-core chokes, eliminate buzzing and improving efficiency, durability and lifespan. And R7 240 is ripe to be overclocked with GPU Tweak, an easy-to-use tool from ASUS that you'll use to adjust clock speeds, voltages and more. Then, use the streaming function to share your achievements with the world.
