| Quicklinx: | 73GYWS00 |
| Mfr#: | ASUSAMD-MID2 |
Exclusive Self-Build Special Bundle
Perfect Performance PC!
Take the fear out of Self-Build with this tested AMD Performance Bundle! We test it so you don't have to! Motherboard, CPU and Memory - Boxed & Ready To Rock!
Asus M4A78LT-M AMD Motherboard
This motherboard supports AMD AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the 45nm manufacturing process.
The motherboard supports DDR3 memory that features data transfer rates of 1800+(O.C.)/1600(O.C.)/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 25.6Gbps. Furthermore, the supply voltage for the memory is reduced from 1.8 V for DDR2 to just 1.5 V for DDR3. This voltage reduction limits the power consumption and heat generation of DDR3 which makes it an ideal memory solution
AMD Phenom II X2 560 3.3GHz Black Edition Processor (HDZ560WFGMBOX)
AMD Phenom II X2 Black Edition processor combines value and unlocked potential for gamers and tuners on a budget. Users can now experience the power of AMD platform technology, codenamed "Dragon" with dual-core configurations. AMD Black Edition processors help users to take control and unleash the maximum potential of Dragon platform technology's unprecedented performance tuning capabilities. With dual-core processors, AMD provides platform level solutions at multiple price points, each of which exceeds expectations for virtually any user.
Patriot Signature 2GB DDR3 CL9 PC3-10600 1333MHz Memory (PSD32G13332H)
Designed with reliability, performance and value in mind, Patriot Signature DDR3 PC3-10600 (1333MHz) is the perfect memory upgrade solution for desktop and workstation systems. Patriot ensures that every memory module meets and exceeds industry standards.
