The ASUS All-in-One PC A6420 is powered by the Intel 4th generation Core processor with DDR3 memory for easy multitasking, enhanced performance, and better energy efficiency in whatever you choose to do.
The ASUSPRO A6420 series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A6420 can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. With HDMI-out ports, A6420 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality.
