Z170 Pro4S - Keeping tools and designs simple
What you've never understood about your computer is that it is scared to death of water, H2O, humidity or whatever you'd like to name it. And even though you do not see the water, actually there may be lots of excessive moist in the air killing your motherboard silently and slowly. No, your motherboard doesn't melt when in contact with water like the wicked witch of the west, but it dies of short circuit.
The power phase design offers smooth power delivery to the CPU, unmatched overclocking capabilities, lower temperature for advanced gamers, and reinforced system stability for taking on all sorts of arduous computing tasks.
Intel LAN provides the best throughput performance, lower CPU utilization, enhanced stability and is able to deliver ultimate network experience to users!
Supports 6th Generation Intel® Core™ Processors (Socket 1151)
Digi Power, 10 Power Phase Design
Supports Dual Channel DDR4 3200+(OC)
2 PCIe 3.0 x16, 3 PCIe 3.0 x1
AMD Quad CrossFireX™, CrossFireX™
Graphics Output Options: DVI-D, HDMI
7.1 CH HD Audio (Realtek ALC892 Audio Codec), ELNA Audio Caps
2 SATA Express, 6 SATA3, 1 Ultra M.2 (PCIe Gen3 x4 & SATA3)
8 USB 3.0 (2 Front, 6 Rear)
Supports Full Spike Protection, ASRock Live Update & APP Shop
