Fatal1ty Z97X Killer: A high-end Z97 Gaming MB with Killer LAN, M.2 socket, and SATA Express interface
- ASRock Super Alloy
- XXL Aluminum Alloy Heatsink
- Premium Alloy Choke (Reduces 70% core loss compared to iron powder choke)
- Dual-Stack MOSFET (DSM)
- NexFET™ MOSFET
- Nichicon 12K Platinum Caps (100% Japan made high quality conductive polymer capacitors)
- Sapphire Black PCB
- Supports 5th Generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
- Supports New 4th and 4th Generation Intel® Xeon®/Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
- Digi Power, 8 Power Phase design
- Supports Dual Channel DDR3 3200+(OC)
- 3 PCIe 3.0 x16, 3 PCIe 2.0 x1
- Supports AMD 3-Way CrossFireX™ and NVIDIA® Quad SLI™
- Graphics Output Options: D-Sub, DVI-D, HDMI
- 7.1 CH HD Audio with Content Protection (Realtek ALC1150 Audio Codec), Supports DTS Connect
- 1 SATA Express, 6 SATA3, 1 M.2 (PCIe Gen2 x2 & SATA, Supports 30mm, 42mm, 60mm, 80mm, 110mm M.2 devices), 8 USB 3.0 (2 Front, 6 Rear), 6 USB 2.0 (4 Front, 1 Rear, 1 Fatal1ty Mouse Port)
- 1 COM Port Header
- Supports ASRock HDD Saver Technology, Full Spike Protection, ASRock Cloud, APP Shop, F-Stream, Key Master, Full HD UEFI
Gaming Armor
- CPU Power - Hi-Density Power Connector
- Memory - 15µ Gold Contact in DIMM Slots
- VGA Card - 15µ Gold Contact in VGA PCIe Slot (PCIE2), PCIe Power Connector
- Internet - Qualcomm® Atheros® Killer™ LAN
- Audio - Purity Sound™ 2
