With its completely re-thought design, the Archos 10b Vision has been thought out with its elongated shape for ease of use. Thanks to its integrated clip it's perfect to clip onto your strap or pocket and with the 1 inch screen browsing your files is made even easier.
The Archos 10b Vision is designed for your life on the move. Small and slim enough to go anywhere, you can carry it with you all the time - this really is an MP3 player you'll love.
