Answer a call from your surfboard. Stream your favorite songs on your run. And do it all while leaving your phone behind. The Apple Watch Series 3 gives you the freedom to go with just your watch.
It delivers important information when and where you need it. Helps you easily perform everyday tasks in seconds. Instantly connects you to the people and things you care about most. All while keeping precise time.
You'll know it when you feel it
Because this smartwatch sits on your wrist, it can give you a gentle tap the instant you receive an alert.
Stay in touch like never before
You won't just send and receive messages, calls, and mail more easily and efficiently. You'll express yourself in unique, fun, and more personal ways. Communicating with the smartphone is discreet, sophisticated, and nuanced - a different way to connect with others.
Messages, calls, and mail designed for your wrist
The ways you communicate on your smartphone are even more immediate on the smartwatch. To read a message or email, just raise your wrist. You can take a quick phone call using the built-in speaker and microphone.
Easy ways to respond
You don't always have time to craft a lengthy response to a message or email. With the smartwatch, you can make a quick but meaningful reply.
Say it with feeling
You don't even have to use words. The Digital Touch feature gives you fun, spontaneous ways to connect with other smartwatch wearers, wrist to wrist.
Sensitive enough to tell a tap from a press
In addition to recognising touch, the smartwatch senses force, adding a different dimension to the user interface. With Force Touch, pressing firmly on the display brings up additional controls in apps.
Technology with a more human touch
This linear actuator inside the smartwatch taps you on the wrist when you receive a notification, press down on the display, or use Digital Touch. The Taptic Engine gives different kinds of notifications and actions their own distinct character. So even with the accompanying audio cues turned off, you can feel the difference between an alarm and an incoming phone call without even looking.
Apple Watch Series 3 (GPS + Cellular) - stainless steel - smart watch with milanese loop - silver - 16 GB
Smart watch
Tracking Data
Distance, time, calories burned, activity, heart rate, steps taken
Wi-Fi, Bluetooth 4G
Navigation
GPS/GLONASS/Galileo/QZSS receiver
Display
OLED 312 x 390 pixels - sapphire glass
Apple S3
Storage
16 GB
Operating System
WatchOS 4
Case
42 mm - stainless steel
Band
Silver - milanese loop - stainless steel
Intelligent Assistant
Siri
Input
Force Touch
Fits Wrist with Circumference
150-200 mm
Notifications
Calendar, SMS, Email
Call handling, music remote handling, camera remote control, listening to music, Retina Display technology, text messages handling
Supported Host Device OS
iOS
Lithium Ion
Battery Run Time
Up to 18 hours
36.4 mm x 11.4 mm x 42.5 mm
52.8 g
0.16 W/kg (head) , 0.18 W/kg (limb)
Smart watch
iOS 11 or later
Supported Mobile Messaging Services
SMS
Notifications
Messaging Services
SMS
Navigation
Tracking Data
