The USB-C to SD Card Reader transfers high-resolution photos and videos at UHS-II speeds to your USB-C-enabled Mac, iPad or iPhone. Designed so it won’t block your other ports, it works with UHS-II SD cards and is backwards-compatible with other SD cards and adapters.
