The Apple Universal Dock offers easy access to a USB port for charging and syncing your iPod or iPhone or for connecting to a TV or speakers. It includes the Apple remote for easy control from across the room.
The Apple Universal Dock serves as a convenient and elegant home base for charging, syncing, and more. Through the use of interchangeable inserts called Dock adapters, it works with iPhone and all iPod models that have a dock connector. So even if you own more than one iPod or iPhone, you can keep just one Dock connected to your computer, stereo, or TV.
And when your iPod or iPhone is in the Dock and connected to a stereo or TV, the included Apple remote lets you experience songs, slideshows, and more from across the room. Just choose a playlist, slideshow, or video, then sit back and enjoy. The Apple remote offers play/pause, volume control, and forward/back buttons for easy control.
Any iPhone or iPod with a dock connector can fit perfectly into the Universal Dock through the use of interchangeable inserts called Dock Adapters. You simply insert the Dock adapter for your particular model, and then plug in your iPod. When you want to connect a different-size iPod or iPhone, simply pop out the Dock adapter and insert another one.
