Any way you look at it, iPad mini is just incredible. And the stunning Retina display is only the beginning. With A7 chip, advanced wireless, and powerful apps - all beautifully integrated with iOS 7 - iPad mini with Retina display lets you do more than you ever imagined. Feature for feature, it's identical to iPad Air in every way. Except for its super-portable, hold-it-in-one-hand, still-just-right mini size.
Now iPad mini looks even more brilliant in your hand. The Retina display has over 3.1 million pixels - a million more than an HDTV. That's a 2048-by-1536 resolution, four times the resolution of the previous-generation iPad mini. In fact, the pixels are so close together, your eyes can't distinguish them. So photos and videos show incredible detail and text is razor sharp. Because the best pixels are the ones you never see.
Thin and light design
Apple packed so many incredible features inside iPad mini. It has a stunning Retina display, the incredibly powerful A7 chip, advanced wireless technologies, and more. Yet it's still thin and light. It's just 0.29 inch thin and weighs less than three-quarters of a pound. So while you can do even more, you won't feel like you're holding any more.
Incredible performance
The Apple-designed A7 chip brings 64-bit desktop-class architecture to iPad. That means up to 4x the CPU speed and up to 8x the graphics performance for everything you do. And still long hours of battery life to study, play, build, and create whatever you want, all you want.
A7 chip
The A7 chip takes iPad to heights of power and speed. Thanks to the A7 chip, apps run faster. Games are more responsive. And everything you do with iPad mini feels quicker, because it is quicker. Up to four times as quick, in fact. But that's just the beginning. And the A7 chip features 64-bit architecture, opening the door for even more robust and powerful apps. Which means even more possibilities for what you can do with iPad mini.
M7 motion processor
iPad mini was designed to be on the move. That's why the M7 coprocessor makes so much sense. It measures motion from your iPad mini by pulling data from the accelerometer, gyroscope, and compass. So your apps can give you a better experience based on the movement of your iPad mini. It's a task that would normally fall to the A7 chip. But M7 is more efficient at it, which saves on power.
Same great battery life
iPad mini is powerful, but not power hungry. Even though it's up to four times as fast as the previous-generation iPad mini, it still gives you the same incredible long-hour battery life. That's because the A7 chip isn't just more powerful, it's also more efficient. So no matter where you go with iPad mini, you'll have the battery power to go even further.
More LTE bands
iPad mini with Wi-Fi + Cellular lets you connect to the Internet even if you're away from a Wi-Fi signal. iPad mini supports even more LTE bands to connect to more cellular data networks around the world. Now you can get online at really fast speeds - faster than broadband in some cases - in more places. And plans are flexible, so you don't have to sign a contract. Some plans even let you share data across multiple devices.
Apple iPad mini 2 Wi-Fi + Cellular - 2nd generation - tablet - 32 GB - 7.9" - 3G, 4G
Tablet
Display
7.9" IPS TFT - LED backlight - 2048 x 1536 (326 ppi) - Multi-Touch
Apple A7 - 64-bit
Storage
32 GB
Cellular Technology
3G, 4G
Cellular Protocols
GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel focus: automatic
Front Camera
1.2 Megapixel
Navigation System
A-GPS
Battery Run Time
Up to 10 hours
13.47 cm x 0.75 cm x 20 cm
341 g
Silver
English / United Kingdom
SAR
1 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 7
Display
Resolution
Touchscreen
Multi-Touch
Anti-fingerprint, Retina display
Apple A7
64-bit Computing
Storage
32 GB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
Audio
Two microphones, speaker
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store
System Requirements for PC Connection
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3 or later, Microsoft Windows XP Home Edition SP3 or later, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
Expansion Slots
1 x Nano-SIM card
1 x headphones , 1 x Lightning
Lithium polymer
23.8 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
Silver
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
Charging via USB, aluminum enclosure, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
Power adapter
Lightning to USB cable
SAR Value
1 W/kg (body)
13.47 cm
0.75 cm
20 cm
341 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
