iPad mini with Retina display is amazing to hold. And behold. Every photo is incredibly detailed and vibrant, and every line of text is remarkably crisp and clear. With higher resolution than an HDTV, it's stunning - on a whole new scale.
iPad mini keeps you connected faster than ever. In more locations than ever. Using two antennas instead of one and MIMO technology, iPad mini delivers twice the Wi-Fi performance of its predecessor.
Any way you look at it, iPad mini is just incredible. And the stunning Retina display is only the beginning. With an A7 chip, advanced wireless, and powerful apps - all beautifully integrated with iOS 7 - iPad mini with Retina display lets you do more than you ever imagined.
Now iPad mini looks even more brilliant in your hand. The Retina display has over 3.1 million pixels - a million more than an HDTV. That's a 2048-by-1536 resolution, four times the resolution of the previous-generation iPad mini. In fact, the pixels are so close together, your eyes can't distinguish them. So photos and videos show incredible detail and text is razor sharp. Because the best pixels are the ones you never see.
Apple packed so many incredible features inside iPad mini. It has a stunning Retina display, the incredibly powerful A7 chip, advanced wireless technologies, and more. Yet it's still thin and light (and mini). So while you can do even more, you won't feel like you're holding any more.
Every little bit as amazing
7.9-inch Retina display
Thin and light design
Apple iPad mini 2 Wi-Fi - 2nd generation - tablet - 16 GB - 7.9"
Tablet
Display
7.9" IPS TFT - LED backlight - 2048 x 1536 (326 ppi) - Multi-Touch
Apple A7 - 64-bit
Storage
16 GB
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel focus: automatic
Front Camera
1.2 Megapixel
Battery Run Time
Up to 10 hours
13.47 cm x 0.75 cm x 20 cm
331 g
Silver
English / United Kingdom
SAR
0.6 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 7
Display
Resolution
Touchscreen
Multi-Touch
Anti-fingerprint, Retina display
Apple A7
64-bit Computing
Storage
16 GB
Communications
Rear Camera
Sensor Resolution
5 Megapixel
Focus Adjustment
Automatic
Geotagging
Front Camera
Sensor Resolution
1.2 Megapixel
FaceTime HD camera
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
Audio
Two microphones, speaker
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store
System Requirements for PC Connection
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3 or later, Microsoft Windows XP Home Edition SP3 or later, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
1 x headphones , 1 x Lightning
Lithium polymer
23.8 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
Silver
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
Charging via USB, aluminum enclosure, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
Power adapter
Lightning to USB cable
SAR Value
0.6 W/kg (body)
13.47 cm
0.75 cm
20 cm
331 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
