| Quicklinx: | HF3NWS00 |
| Mfr#: | MTJV3ZM/A |
AirPods Pro 2, featuring pro-level Active Noise Cancellation,¹ Adaptive Audio, Transparency mode², Personalised Spatial Audio³ and hearing health features including Loud Sound Reduction, Conversation Boost and Background Sounds.
Groundbreaking sound
AirPods Pro 2 with hearing health features including Loud Sound Reduction, Conversation Boost and Background Sounds.
Intelligent noise control
Active Noise Cancellation removes up to twice as much background noise.¹ Transparency mode lets you hear the world around you, and Adaptive Audio seamlessly blends Active Noise Cancellation and Transparency mode for the best listening experience in any environment.² And when you’re speaking to someone nearby, Conversation Awareness automatically lowers the volume of what’s playing.(4)
Improved sound and call quality
The Apple-designed H2 chip helps to create deeply immersive sound. The low-distortion, custom-built driver delivers crisp, clear high notes and full, rich bass in stunning definition. Voice Isolation improves the quality of phone calls in loud conditions.
Customisable fit
Includes four pairs of silicone tips (extra small, small, medium, large) to fit a wide range of ear shapes and provide all-day comfort. The tips create an acoustic seal to help keep out noise and secure AirPods Pro 2 in place.
Dust, sweat and water resistant
Both AirPods Pro 2 and the MagSafe Charging Case are IP54 dust, sweat and water resistant, so you can listen comfortably in more conditions.(5)
Personalised spatial sound
With sound that suits your unique ear shape along with dynamic head tracking, AirPods Pro 2 deliver an immersive listening experience that places sound all around you.³ You can also listen to selected songs, shows and movies in Dolby Atmos.
A higher level of control
Simply swipe, press and hold the stem to manage playback functions using Touch control. And with Siri Interactions, simply nod your head yes or shake your head no when Siri asks if you’d like to hear a message, answer a call or manage a notification.(4)
Long battery life
Get up to 6 hours of listening time with Active Noise Cancellation enabled.6And get up to 30 hours of total listening time with Active Noise Cancellation enabled, using the case.(7)
A more capable case
Keep track of AirPods Pro 2 with Precision Finding and a built-in speaker.(8) A lanyard loop helps keep your AirPods Pro 2 close. Charge with an Apple Watch or MagSafe charger, USB-C Charge Cable or Qi-certified charger.(9)
Disclaimers
¹Compared with AirPods Pro (1st generation) and AirPods 4 with Active Noise Cancellation.
²Device performance and noise control features like Active Noise Cancellation, Adaptive Audio and Transparency can be affected by debris or earwax build-up. Clean the device regularly to maintain performance and full feature functionality. Refer to support.apple.com/102672 for cleaning instructions.
³Spatial Audio works with compatible content in supported apps. iPhone with TrueDepth camera required to create personalised profile.
4Available on compatible devices with iOS 18, iPadOS 18 or macOS Sequoia and later when paired with AirPods 4, AirPods 4 with Active Noise Cancellation or AirPods Pro 2 with the latest firmware.
5AirPods Pro 2 are dust, sweat and water resistant for non-water sports and exercise, and are IP54 rated. Dust, sweat and water resistance are not permanent conditions.
6Testing conducted by Apple in August 2023 using pre-production AirPods Pro 2 with MagSafe Charging Case (USB-C) and software paired with pre-production iPhone 15 Pro units and software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256Kb/s AAC encoding). Volume was set to 50% and Active Noise Cancellation was enabled. With Spatial Audio and Head Tracking enabled, listening time was up to 5.5 hours. Testing consisted of full AirPods Pro battery discharge while playing audio until the first AirPod Pro stopped playback. Battery life depends on device settings, environment, usage and many other factors.
7Testing conducted by Apple in August 2023 using preproduction AirPods Pro 2 with MagSafe Charging Case (USB-C) and software paired with pre-production iPhone 15 Pro units and software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50% and Active Noise Cancellation was enabled. Testing consisted of full AirPods Pro battery discharge while playing audio until the first AirPod Pro stopped playback. The drained AirPods Pro were charged to 100 per cent, then audio playback was resumed until the first AirPod Pro stopped playback. This cycle was repeated until both the AirPods Pro and charging case were fully discharged. Battery life depends on device settings, environment, usage and many other factors.
8Precision Finding requires a U1-equipped iPhone, availability varies by region.
9MagSafe charging requires a compatible MagSafe charger. Wireless charging requires a Qi-certified wireless charger. AirPods Pro 2 charging case also works with the Apple Watch charger or USB-C connector.
