Introducing AirPods Max — a perfect balance of exhilarating high-fidelity audio and the effortless magic of AirPods. The ultimate personal listening experience is here.
The over-ear headphone has been completely reimagined. From cushion to canopy, AirPods Max are designed for an uncompromising fit that creates the optimal acoustic seal for many different head shapes — fully immersing you in every sound.
AirPods Max combine high-fidelity audio with industry-leading Active Noise Cancellation to deliver an unparalleled listening experience. Each part of their custom-built driver works to produce sound with ultra-low distortion across the audible range. From deep, rich bass to accurate mids and crisp, clean highs, you’ll hear every note with a new sense of clarity.
With a powerful Apple-designed H1 chip in each cup, our custom acoustic design and advanced software, AirPods Max use computational audio to create a breakthrough listening experience. By tapping into each chip’s 10 audio cores, computational audio helps block outside noise, adapts audio to the fit and seal of your ear cushions, and makes movie scenes sound like they’re happening all around you.
Good to know
- You'll be heard loud and clear on phone calls thanks to beamforming mics which isolate your voice, even on windy days
- They create an acoustic seal around your ears to fully immerse you in sound
- Your music automatically pauses when you remove the headphones and resumes when you put them back on
- A simple "Hey Siri" summons your voice assistant without lifting a finger - control your music, calls, volume and more
- One-tap setup lets you easily pair with and switch between all your Apple devices
- A quick 5-minute charge gives you up to 1.5 hours of playback - perfect when you're in a rush
Used stock
All used stock comes with a 90 day warranty.
Condition: used condition
Ref: G31Z 048539
- Accessories:This part of the stock item is present and in good condition
- Packaging:This part of the stock item is present and in good condition
- Functional:This part of the stock item is present and in good condition
- Software:This part of the stock item is present and in good condition
- Manuals:This part of the stock item is present and in good condition
