M1 Pro scales the amazing M1 architecture to new heights - and they bring a system on a chip (SoC) architecture to a pro notebook. More CPU cores, more GPU cores, and more unified memory than M1. Along with a powerful Neural Engine for supercharged machine learning and upgraded media engines with ProRes support, M1 Pro allows pros to do things they never could before.
Scary fast
M1 Pro takes the exceptional performance of the M1 architecture to a whole new level for pro users. Even the most ambitious projects are easily handled with up to 10 CPU cores, up to 16 GPU cores, a 16-core Neural Engine, and dedicated encode and decode media engines that support H.264, HEVC, and ProRes codecs.
All-day power
Ferocious performance with game-changing battery life - that efficiency is the magic of Apple silicon. A single charge lets you compile up to four times as much code in Xcode or edit images for up to twice as long in Lightroom Classic. MacBook Pro delivers the same amazing performance whether it's plugged in or not.
The coolest part
Advanced thermal systems move 50 percent more air, even at lower fan speeds. And thanks to the efficiency of Apple silicon, the fans never turn on for many tasks you do every day.
Fast and vast
Get jaw-dropping 7.4 GB/s read speeds from the SSD - up to two times faster than the previous generation. So you can open 8K videos instantly or store hundreds of thousands of RAW photos at once.
Feast your eyes on XDR
Liquid Retina XDR. The display features Extreme Dynamic Range and a million to one contrast ratio. HDR content comes to life in photos, video, and games - with refined specular highlights, incredible detail in shadows, and vibrant, true-to-life colors. Each display is factory calibrated and features pro reference modes for HDR color grading, photography, design, and print production.
ProMotion
ProMotion comes to Mac for the first time, making everything from scrolling through a web page to gaming super fluid and responsive - while also reducing power consumption. With refresh rates of up to 120 Hz, the adaptive technology automatically adjusts to match the movement of the content. Video editors can also choose a fixed refresh rate that precisely aligns with their footage.
Heads up - the camera's 1080p HD
Staying connected is more important than ever. That's why the MacBook Pro camera has double the resolution - 1080p - and uses a lens with a wider aperture that lets in more light. Together with a larger image sensor that has more efficient pixels, the camera delivers two times better low-light performance.
Three studio-quality mics
Thanks to mics with an up to 60 percent lower noise floor, MacBook Pro can capture even the subtlest sounds. And the three-mic array uses directional beamforming so your voice always comes through loud and clear.
Six-speaker sound system
Four force-canceling woofers reveal notes up to a half-octave deeper and fill the room with up to 80 percent more bass. And the high-performance tweeters project clearer, fuller vocals.
Spatial audio
Thanks to the room-filling six-speaker system and advanced algorithms, MacBook Pro supports spatial audio when playing music or video with Dolby Atmos, creating a sophisticated, three-dimensional soundstage. Combine that with the Liquid Retina XDR display, and it's like having a portable theater.
More plugged in than ever
Transfer photos and videos with an SDXC card reader. Connect to TVs or displays with HDMI output. Listen using a 3.5 mm headphone jack that detects and automatically adjusts for high-impedance headphones. Connect to high-speed peripherals or displays with three Thunderbolt 4 ports. And fast-charge using the quick-releasing MagSafe 3 port.
Pro power meets pro keyboard
The Magic Keyboard brings a full-height function key row to MacBook Pro - with the tactile feel of mechanical keys that pros love. It includes keyboard shortcuts for Spotlight, Dictation, and Do Not Disturb. And Touch ID has a tactile ring that guides your finger for a fast, easy, secure way to unlock your Mac.
macOS Monterey and Apple silicon - beauty and the beast
Use a single keyboard and mouse or trackpad to work seamlessly between your Mac and iPad with Universal Control. Automate complex tasks with Shortcuts. Share your screen, watch together, or collaborate with FaceTime. And browse with the best Safari yet. When it's time to concentrate, Focus lets you control which people and apps can reach you.
Apple MacBook Pro - 16.2" - Apple M1 Pro - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
macOS Monterey 12.0
Apple M1 Pro
16 GB (unified memory)
Storage
512 GB SSD
Display
16.2" Mini LED backlight 3456 x 2234 @ 120 Hz - 254 ppi
Graphics
Apple M1 Pro 16-core
Input Device
Force Touch trackpad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
Up to 21 hours
Ambient light sensor
Security
Fingerprint reader
Silver
35.57 cm x 24.81 cm x 1.68 cm
2.1 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Monterey 12.0
Processor / Chipset
CPU
Apple M1 Pro
Number of Cores
10-core
RAM
Storage
Main Storage
512 GB SSD soldered
Display
16.2"
LCD Backlight Technology
Mini LED backlight
Resolution
3456 x 2234
V-Sync Rate at Max Res.
120 Hz
Widescreen
Pixel Density (ppi)
254
Image Brightness
1000 cd/m²
Colour Support
1 billion colours
BFR/PVC-free, Mercury free, beryllium free, arsenic free, ProMotion technology, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), True Tone technology, 1600 cd/m² peak brightness (HDR)
Keyboard Name
Magic Keyboard
Audio & Video
Graphics Processor
Max Monitors Supported
2 external monitor(s)
Video System Features
Hardware-accelerated H.264, HEVC, ProRes and ProRes RAW, video decode engine, ProRes encode and decode engine, video encode engine
Camera
Yes - 1080p
Camera Features
Advanced image signal processor (ISP), FaceTime 1080p HD camera
Sound
Six speakers, three microphones
Dolby Atmos
Input
Keyboard, Force Touch trackpad
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
100 Wh
Run Time
Up to 21 hours
Battery Run Time
Video playback: up to 21 hours , Web browsing: up to 14 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
140 Watt
Connections & Expansion
Interfaces Details
3 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) , Headphone output , HDMI
Memory Card Reader
Yes (SDXC Card)
Software
Software Included
Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Pay
Silver
Case Material
Aluminum
Integrated Options
Security
Fingerprint reader
VoiceOver screen reader, Voice Control
USB-C power adapter
Localization
2.1 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
