The M3 chip brings even greater capabilities to the super-portable 13-inch MacBook Air. With up to 18 hours of battery life,(1) you can take it anywhere and blaze through work and play.
- LEAN. MEAN. M3 MACHINE — The blazing-fast MacBook Air with the M3 chip is a super-portable laptop that sails through work and play.
- PORTABLE DESIGN — Lightweight and just over 11 millimetres thin, so you can take MacBook Air anywhere you go.
- GET MORE DONE FASTER — The powerful 8-core CPU and up to 10-core GPU of the Apple M3 chip keep things running smoothly.
- UP TO 18 HOURS OF BATTERY LIFE1 — Amazing, all-day battery life so you can leave the power adapter at home.
- A BRILLIANT DISPLAY — The 13.6-inch Liquid Retina display(2) supports one billion colours.
- LOOK SHARP, SOUND GREAT — Everything looks and sounds amazing with a 1080p HD camera, three mics, and four speakers with Spatial Audio.
- APPS FLY WITH APPLE SILICON — All your favourites, from Microsoft 365 to Adobe Creative Cloud, run lightning fast in macOS.(3)
- GET CONNECTED — MacBook Air features two Thunderbolt ports, a headphone jack, Wi-Fi 6E,(4) Bluetooth 5.3 and a MagSafe charging port. And connect up to two external displays with the laptop lid closed.
- IF YOU LOVE IPHONE, YOU’LL LOVE MAC — MacBook Air works like magic with your other Apple devices.(5) Start an email on your iPhone and finish it on your Mac. Send text messages from your Mac. And much more.
Configurable options are available.
(1) Battery life varies by use and configuration. See apple.com/uk/batteries for more information.
(2) The display on the 13-inch MacBook Air has rounded corners at the top. When measured as a standard rectangular shape, the screen is 13.6 inches diagonally (actual viewable area is less).
(3) Apps are available on the App Store.
(4) Wi-Fi 6E available in countries and regions where supported.
(5) Requires iCloud and internet connection.
