Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
Software package
SmartConnect software for remote power monitoring feature availability varies by terms of use
Communication port support
SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
High online efficiency
Reduces utility costs, generates less heat.
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs.
Cold-start capable
Provides temporary battery power when the utility power is out.
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS C - UPS - 600 watt - 1000 VA - with APC SmartConnect
