This product is a specialized enclosure with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment
Integrated power distribution
Provided with a rack power distribution unit servers and other equipment are ready for deployment
Six vertical 0U accessory channels
Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space
Dedicated rear cable access point
The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling
Acoustic foam lining for noise dampening
Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment
Adjustable equipment mounting rails
The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in
Removable side panels
Provides customers with easy accessibility to equipment
Compatibility with enhanced enclosure access security options
Enclosure is provided standard with front, rear, side locking components and is designed for compatibility with increased security options such as combination-style and electronic swipe access handles
APC NetShelter CX - rack - 18U
Rack
Package Content
Side panels, keys, PDU (Power Distribution Unit), levelling feet, casters
Rack Size
19"
Height (Rack Units)
18U
75 cm x 113 cm x 101.5 cm
131 kg
Noise reduction, lockable, built-in cooling fan
Rack
Package Content
