The APC Basic Rack PDU provides a reliable power distribution solution for your computing equipment. With 14 power IEC 60320 C13 output connectors, it ensures that multiple devices can be powered simultaneously, making it an ideal choice for busy IT environments.
Wide compatibility
Designed to be compatible with PC systems, this power distribution unit seamlessly integrates into your existing setup. Its rack-mountable form factor allows for a tidy and organized installation, enhancing the overall efficiency of your workspace.
Robust environmental adaptability
Operating efficiently in a wide range of humidity (5 - 95% non-condensing) and temperature (0°C to 50°C), the APC Basic Rack PDU is built to perform under various environmental conditions, ensuring reliability and longevity of your critical equipment.
