SurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge
IEEE let-through ratings and regulatory agency compliance
APC surge protectors undergo stringent testing by IEEE, and are awarded "let-through ratings", which indicate the maximum voltage level that can possibly reach your equipment after a surge or voltage spike has passed through an electric surge protector. Lower IEEE let-through ratings indicate better protection and performance. The APC Essential SurgeArrest series offers optimal performance with a let-through rating of less than 330V to 500V for North American products, and a rating of less than 15% for products sold worldwide. All APC products comply with local agency safety requirements, including UL in North America and CE/Kema/Gost/C-tick/A-Tick/Telepermit in their respective regions
Right Angle Plug
Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too
Overload Indicator
Indicator illuminates when connected equipment draws more power than unit’s capacity. To remedy the condition, unplug less vital equipment
APC SurgeArrest Audio-Video - surge protector
Surge protector - external
1.2 kg
United Kingdom
Input Voltage
AC 230 V
Input Connectors
1 x power BS 1363
Output connectors
8 x power BS 1363
Silver
12.2 cm x 4.2 cm x 37.2 cm
Silver
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
8 x power BS 1363
Max Electric Current
13 A
Dataline Surge Protection
Phone line - RJ-11 , Cable TV
Surge Suppression
Surge Energy Rating
2525 Joules
EMI/RFI Noise Filtration
70 dB
Power cable - integrated - 3 m , 2 x phone cable - external - 1.8 m , Coaxial RF cable - external - 60 cm
