Back
Monitors
AOC E2250SDA 22" 1680 x 1050 5MS DVI-D VGA Speakers LED Monitor
Quicklinx:
843PWS00
Mfr#:
e2250Sda
Back
Marketing description is not available.
AOC e2250Sda - LED monitor - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:9
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
56.2 cm x 10.9 cm x 42 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
GOST, DDC-1, DDC-2B, CB, FCC, DDC/CI, RoHS, ISO 9024-307
3-year warranty
Display Type
Diagonal Size
22"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
83 Hz
Horizontal Refresh Rate
75 kHz
Video Bandwidth
146.25 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Power off timer, HDCP, Eco-Mode, i-Menu, e-Saver technology
3.8 kg
Audio
Speakers - integrated
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-4/+17
VESA Mounting Interface
75 x 75 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
Microsoft Windows 7
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
