AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
Wide viewing angle
Wide Viewing Angle features display colour accurately at viewing angles of up to 178°. This way, it does not matter where you choose to view it from, colours will be displayed perfectly.
Full Ergonomics
Feel the comfort! AOC's height, tilt and swivel-adjustable stands help you find the most comfortable and healthy position.
USB-C
Simplify the connections with one cable only. The USB-C connection provides DisplayPort Alternate Mode for transferring high-resolution video signals from a notebook to the monitor while simultaneously charging the notebook's battery from the monitor with USB power delivery. Additionally, the USB 3.1 ensures lightning-fast data transmission, so even transferring a 4K movie can be done in less than one minute.
Pivot
Thanks to its pivot function, your monitor can be rotated by 180° from landscape into portrait mode, especially useful for desktop publishing.
AOC 24P2C - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/419811
Energy Class
Class E
Power Consumption (On mode)
18 W
USB 3.2 Gen 1 hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
107% sRGB, 79% Adobe RGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
54.02 cm x 20.01 cm x 51.3 cm
5.01 kg
Environmental Standards
TCO Certified Displays 9
RoHS, Lead-Free, Mercury-free
3-year warranty
Display Type
Energy Class
Class E
Energy Class (HDR)
Class F
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Flicker Free technology
54.02 cm x 20.01 cm x 51.3 cm - with stand
5.01 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DisplayPort 1.2 , USB-C/DisplayPort Alt Mode (power up to 65W) , 4 x USB 3.2 Gen 1 , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+35
Swivel Angle
180
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - 1.8 m
Input Voltage
18 W
18 kWh/1000h
Power Consumption HDR (On mode)
19 kWh/1000h
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 54.02 cm - depth: 5.07 cm - height: 32.64 cm
