Display specialist AOC e2250Swh sets a course for both office and home with the 50 ID. The slim widescreen come in a great design. Thanks to numerous features the display equipped with LED backlights impress with very good image quality.
AOC e2250Swh is characterized by a classic design. The monitor render even the fast movie sequences fluently and razor-sharp. And available with digital inputs, the large versions offer full HD resolution. Settings can be adjusted comfortably via the user friendly onscreen menu.
Slim and classic design
At its slim region, the monitor which sport hairline textures on the rear side as well as the base, is just 1.6 cm deep. With the good look, you can easily fit into almost every setting.
Focus on the environment with LED technology
Resource-efficiency and energy saving are of high importance at AOC. Thanks to the electricity-saving LED backlight technology, the monitor is manufactured entirely mercury-free. Users can individually contribute to an even low overall consumption.
AOC e2250Swh - LED monitor - Full HD (1080p) - 21.5"
