Anker 533 Wireless Power Bank (PowerCore 10K)
The Freedom to Charge Anywhere
Wireless Charging. Anywhere.
The convenience of wireless charging is no longer confined to your home or office. Qi-certified charging up to 10W lets you fully charge an iPhone 11 in less than 4 hours no matter where you are.
Choose How You Charge
With wireless, USB, and USB-C charging all available, PowerCore gives you unprecedented choice over how you charge. You can even use all of them at once to charge 3 devices simultaneously.
High-Speed Charging
The 18W USB-C port offers the kind of charging speeds that you normally only find in a wall charger. Charge an iPhone 11 to 50% in 30 minutes or fully charge a Galaxy S20 in less than 2 hours.
Power a Full Day
PowerCore is equipped with a 10,000mAh cell capacity to keep your devices charged for at least a full day. Charge an iPhone 11 or Pixel 4 more than twice, or charge a Galaxy S20 over 1.5 times.
Universal Compatibility
Qi-certification offers flawless wireless charging with compatible devices, while our exclusive PowerIQ 3.0 technology ensures optimized charging to virtually any mobile device including phones, tablets, and more.
Built-In Phone Stand
Slide-out the built-in phone stand to watch videos while charging. Note: Only wired charging can be accessed while using the phone stand.
Rapid Recharge
Connect an 18W charger (not included) to the USB-C port to fully recharge the internal battery in just 4.5 hours.
Notes
- This wireless charger does not feature MagSafe-style magnetic alignment, and therefore is not able to charge the iPhone 12 series magnetically.
- The wireless charging feature does not work with the Apple Watch series or Samsung Watch series.
- Do not use a 5W charger to charge your phone wirelessly and recharge PowerCore simultaneously. To charge simultaneously at full speed, it’s recommended to use a charger with at least an 18W output.
- Phone cases thicker than 5 mm, magnetic attachments, metal attachments, stands, or credit cards will interfere with wireless charging.
- Place your phone on the center of the wireless pad to ensure stable charging. If your phone does not show as charging, adjust the position of your phone.
- Press the power button to activate wireless charging.
- 10,000 mAh is the total of the nominal rated capacity of internal battery cells.
