- Prop It Up: Features a versatile built-in foldable kickstand that keeps your iPhone 13/12 upright for a comfortable viewing angle.
- Strong and Snappy: The super-strong magnet snaps magnetically into place to ensure perfect alignment and an efficient charge.
- Slim and Compact: The sleek and slim design is only 0.5 inch (12.8 mm) thin, so you can single-handedly take calls, selfies, and more.
- From Small to Smaller: Anker's new Mini Cell technology reduces the size of the overall battery without compromising power and charging efficiency.
- What You Get: Anker 622 Magnetic Battery (MagGo), 23.6 inch (60 cm) USB-C to USB-C cable, welcome guide, worry-free 24-month warranty, and friendly customer service.
To Hold or to Fold
The magnetic portable charger holds your iPhone 13/12 in place while charging and combines it with a kickstand that can unfold to function as a phone stand.
Two-Way Charge
Consisting of USB-C input and output ports, you can now quickly recharge the portable charger or power up any compatible USB-C devices.
Safety First
Anker's exclusive MultiProtect technology comes with advanced safety features like temperature control, overload protection, and more to let you charge with zero worries.
Compatibility:
iPhone 13 / iPhone 13 Pro / iPhone 13 Pro Max / iPhone 12 / iPhone 12 Pro / iPhone 12 Pro Max with a magnetic phone case.
- For best results, use a 12W power adapter (not included).
- Not compatible with non-magnetic phone cases, such as OtterBox defender cases.
- Magnetic and metal attachments such as cards, keys, and pop grips will interfere with charging.
- The magnetic charge provides up to 7.5W maximum power.
- When the portable charger is charging or discharging, some heat may be generated due to energy loss during transmission. This is a normal occurrence.
