In a class of its own, AMD FirePro W4100 graphics, including four-display support, is the ideal choice for users who need a performance boost to address their evolving workflows.
The new 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in processing power and graphics performance.
AMD Eyefinity 2.0 multi-monitor technology
AMD Eyefinity multi-monitor control technology features support for stereo 3D, universal bezel compensation and brand display configurations. AMD Eyefinity 2.0 enables easy multi-display setup and customization, virtually unlimited number of display devices, stereo 3D-multi-display stereoscopic 3D support via DisplayPort.
Full 30-bit display pipeline
With a full 30-bit display pipeline producing more than one billion colors, the AMD FirePro is ideally suited for applications that benefit from accurate color reproduction and superior visual quality.
PowerTune
This state of the art power management technology provides direct control over GPU power usage. Applications enjoy ultimate performance with dynamic clock optimization, while minimizing workstation energy usage.
AMD Zerocore Power technology
AMD ZeroCore Power technology is the AMD exclusive technology that provides idle power reduction by shutting down GPU.
Quad HD display support
4K support for ultra-high-resolution display devices and advanced configurations through DisplayPort and AMD Catalyst Pro drivers ensures future-forward compatibility for advanced workflows.
Projector overlap support
Easily refine display alignment settings when configuring multiple, high resolution display devices or projectors.
Stretch display resolutions to prevent bezel interference and image distortion when displaying a single large image across multiple displays.
Video Codec Engine (VCE)
Powerful, "fixed-function" multi-stream hardware dramatically improves the performance of HD encoding for a range of applications and pipelines.
HydraVision
Use HydraVision to manage desktop displays and workspaces in multi-display environments: explicitly set the behavior of pop-up windows and dialogs in different applications though Desktop Manager, provide multiple layers of the desktop workspace through Multi Desktop, restrict application window placement across multiple desktops through HydraGrid.
Low profile design
It enables flexible installation in a variety of computing systems, from small form factors to full-height systems.
