Newton X fanless case for IntelĀ® NUC support 2.5" SATA HDD / SSD
- Aluminium fanless CPU cooling design
- Ideal for business, education and embedded environments
- Stylish front panel diamond edge finish
- Support IR function
- Compatible with the following IntelĀ® NUC motherboard: D54250WYB / D34010WYB
- Suitable for VESA mounting
- USB 3.0 port & Support IR remote function
- Antenna fitting holes
- Kensington lock
- Totally silent fanless CPU cooling design
Spec
- Material Aluminium
- Motherboards types UCFF 4" X 4"
- Dimensions 150 x 185 x 47mm (W x D x H)
- Weight 1270 g
- Drive bays 2.5" SSD/HDD
- Front I/O Power button, power and HDD led, USB 3.0 port x 2, IR receiver opening, HD Audio in / out
- Antenna fitting holes 2
- Security Kensington lock
- VESA mounting Support
- Product code A-NUC09-A1B
