Newton Fanless case for NUC systems
- Aluminium fanless CPU cooling design
- Ideal for business, education and embedded environments
- Form factor: UCFF 4" X 4"
- Suitable for VESA mounting
- Antenna fitting holes
- Kensington lock
- Compatible with the following NUC motherboard: Intel DCP847SK / Intel D33217GKE
Spec
- Material Aluminium
- Motherboards types UCFF 4" X 4"
- Dimensions 150 x 150 x 47mm (W x D x H)
- Weight 925 g
- Antenna fitting holes 2
- Security Kensington lock
- VESA mounting Support
