It offers ultra compact and low noise cooler for Intel Core 2 Duo and Core i3 CPU's. The low profile design with embedded fan makes it a perfect solution for mini-ITX, HTPC and SFF systems.
Aluminum heat-sink and enter bearing fan ensure high efficiency and long life. High engineered multi directional aluminum heat-sink maximizes heat dissipation and PWM fan provides optimal CPU, motherboard and VRM cooling with minimal noise levels.
