The ultra quiet AK-CCE-7101CP uses a high engineering omni directional heatsink providing efficient CPU and motherboard zone cooling. The fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
AK-CCE-7101CP is designed to work with CPU's up to 95 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
